What are the biggest tires that will fit? - Ford Powerstroke Diesel Forum
Old 12-26-2007, 01:43 PM
I have a 04 F250 CC 4x4 with a leveling kit. What is the largest tire I can fit with an 18 inch rim on my truck? I was going to go with a 305/65/18 BFG. Any help is appreciated. Thanks
Old 12-26-2007, 02:01 PM
is the 18" wheel stock or aftermarket? that size is about as big as i would go... youll more than likely hit the leaf springs when turning
Old 12-26-2007, 02:04 PM
KVFD
295's thats what i got on my truck
Old 12-30-2007, 11:02 AM
Here's my stock height 2005 with 325/65/18s...basically a 35X13.50. ProComp Xtreme AT tires btw...
Rub just a tad at full lock, but other than that, they fit great. Never had a rubbing issue while offroad either.
Old 12-30-2007, 12:29 PM
I am running 35 12.50x18 Toyo OPMT's at stock height and they dont rub at all. It is tight but no rubbing.
Old 12-30-2007, 07:44 PM
Send a message via ICQ to B Pic
does that go with an 06 F-350also, that has just a levein kit and stock 18-8rims and what is the largest tire for my truck, goin to run cooper stt's, thanks just joined
Old 12-30-2007, 08:13 PM
Send a message via AIM to Lifsvr7 Send a message via Yahoo to Lifsvr7
Keep in mind that yours is a 04... and everyone elses is 05+ difference?? 04 have leafs, and years after went to coils...
.o2
Old 12-30-2007, 09:44 PM
I would think that you would have to consider what type of leveling you kit you are running. Is it an add a leaf, shackle, spring pack, or completely new leafs? It seems that max tire size could differ depending on the size of the leveling kit you are running since leveling kits seem to run between 1.5 inches to 3.5 inches. Just something to think about.
Moon
Old 12-31-2007, 04:06 AM
DJM DJM is offline
You can prety much put 35's on any of the stock superduty's but you might have to space out the bumper with a leveling kit you should be just fine to run 35's coil or leaf front end Most people get the tire rub on the back side of the fender well just depends on wheel back spacing.
Old 01-01-2008, 03:48 PM
It's all about the wheel & backspacing. Marv- kudos on you're truck. very slick SD.
