How to detail engine compartment? - Ford Powerstroke Diesel Forum
Old 02-10-2013, 10:16 PM
Sorry if this is the wrong forum to ask this question but what would you recommend would be the best way to give the engine a good shampoo? Mine is getting pretty grim looking and there is a lot of scary electrical components there. Thanks
Old 02-10-2013, 11:07 PM
Winning DUHHH
I use the pressure washer! I start it up, let it run and douche it down!!
Sent from AutoGuide.com App
Old 02-10-2013, 11:13 PM
Last time I used Mean Green I bought at the Dollar Store. Sprayed it on, waited a few minutes then hosed it of... Repeat as necessary.
Old 02-11-2013, 07:30 AM
Thanks Dave, so getting water in there isn 't a big deal?
Old 02-12-2013, 06:41 PM
its not a big deal but it is.. I cover up the alternator, batteries, filter, ficm with trash bags. Then i wash the engine down with water out of a hose, no pressure washer. Then i air dry it with a leaf blower.. Do not wash the engine with the motor running- you do not want cold water to hit a hot engine block.
Old 02-12-2013, 06:45 PM
Good tips, I kinda thought that hitting anything under the hood with a pressure washer might not go well.
Old 02-12-2013, 07:04 PM
thats how i've done it for years.
Old 02-13-2013, 06:38 PM
I use CRC 6-56 after the engine is dry. Apply with a dry cloth, spray on cloth or on engine parts, then wipe with same rag.
Leaves a nice protective coating on metals and plastics.
Renews the black on hoses, wire loom, weather stripping etc.
Gets rid of the white corrosion spots on bare aluminum too.
I wipe everything down under the hood, leaves a nice shine!!!
Old 02-13-2013, 07:43 PM
Thanks crazy!
