| 6.0L Exterior Discussion Body and Accessories Talk |
Need some inches in the rear
But not that kind
![]() My 6" Fabtech lift for the 2wd was a bit off in the description...its actually 6 in the front but just a 3" block in the rear. Now Im sitting eyes to the sky (prerunner style), and I need to fix it! Does anyone know of any add-a-leafs out there for the 2wd, or any other easy fix to this problem? I dont want to go so far as airbags though.... Thanks guys |
i know deaver has been working on some stuff for the sd models, you might have to check teh weight ratings however... they build springs to any specification you want, im sure they can help you out
superlift, pro comp, fabtech all make add a leafs for the rear....
But are the springs for the 2wd the same as the 4wd? All the companies that list add-a-leafs for my year/model only show 4wd.
Thanks |
i am not familiar with the front end of a 2wd... is there a hollow axle????? if you have a leaf spring front end with a beam then it shouldnt be a problem, but i am sure anyone making add a leaf kits can tell you over the phone...
-Raul |
Absolutely, please do. Thanks Raul. What should that get me? About another 2-3 inches?
it will get you approx 2 more inches in the rear..... ill PM you in a sec
