Box Size? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-02-2013, 02:46 PM Thread Starter
DieselV8's Avatar
Box Size?
Is a box on an ext cab 08 the same the same size as as box on an 06 Crew Cab?
06 F250 Crew Cab, Lariat-FX4, ScanGauge II, High idle mod, Heated mirror switch mod, Sinister bypass oil filter and coolant filter, Fumoto valve, Zoodad, Blue Spring
DieselV8 is offline
post #2 of 3 Old 02-02-2013, 02:53 PM
TOPFUELF250's Avatar
If they are both long beds then they will be the same and if they are both short beds they will be the same. I don't think the type of cab has anything to do with it but, I'm no expert.
TOPFUELF250 is offline
post #3 of 3 Old 02-02-2013, 03:02 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yea they are the same, long bed is 8ft and short bed is 6 3/4ft regardless of the cab
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
