New tires rubbing - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-24-2007, 09:48 AM Thread Starter
Norwegian Viking's Avatar
Send a message via MSN to Norwegian Viking
Question New tires rubbing
Got my new rims and tires too day, but they are rubbing .
Its rubbing big in the front on the plastic under the front bumper.
But its also rubbing in the back off the tires, in the plastic "fender" inside the weel hous, if you understand what i try to say.
I must cut out something in the fron, but what i am going too do in the back side, i dont know .
Do enyone in her hade same problems, and you you give me some idea and maby som pix on how too do this pleas
The tires are Procomp AT 315/75-16 on Mickey Thomson 10/16" rims.
Norwegian Viking
(from Norway)
PS: pleas visit my gallery and leave a coment
No Smoke No Power, No Power No Fun, No Fun No Life !
F250 PSD 6.0 2003. SCT x3, Smittybuilt stainless bullbar, Rollbar, 31/75-16 Procomp All Terrain on Mickey Thomson Cassic II 10x16", Procomp 2" lift leafs front, F350 blocks in rear, Procomp MX6 adjustable.
Norwegian Viking is offline
post #2 of 11 Old 11-24-2007, 09:53 AM
duct tape & zip ties
bigcountrysg's Avatar
Sounds to me like your backspacing on your rims is wrong. You can get wheel spacers to move the rims outward but I don't know if that will help you. As I do not know how off your backspacing is. But most likely that is the problem. I would go to a tire/rim store like Discount Tire or someplace like that. Take your stock rims and have them measure the back spacing for you. If your 33x12.50R16 did not rub then it is not the tire size. It is the backspacing on the new rims.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 11 Old 11-24-2007, 12:16 PM Thread Starter
The back space is 4 7/16" on a 10/16 rim, spacer will make ewen more rubbing.
The space to leaf spring in full turn, are perfect 1-1,5".
The rims and tiers that i have on are 8/16" whit 4" back pace, and 305/70-16, this tires had minor rubbing in the bak of the tires, beafore the lift, but not after.
The rims igot today are perfect for the truck i think, beacaus it will make the tires stick outside the truck and making that mean look :-)
Norwegian Viking
(from Norway)
post #4 of 11 Old 11-24-2007, 12:22 PM
B4SouthernMiss22's Avatar
viking forgot to mention that you do have to make a slanted cut on your bumper plastic. how bad the rubbing?
2001 F-250 7.3. Garrett GTP38R ball bearing turbo, MBRP 4" exaust, muffler delete mod, Bully Dog 6 pos. chip, Edge CTS, 4" suspention lift, and moto metal 20's w/ 35/12.50/20 nitto Trail Grapplers
B4SouthernMiss22 is offline
post #5 of 11 Old 11-24-2007, 12:31 PM Thread Starter
I coud see on youre pix the other day that you hade cut some plastic in the front, same i mst do.
The biggest problem is in the back of the front tires.
Ther is rubbing realy god, maby as mutch as 3/4" the tires are pressing the plastic back.
Whas thinking about trying too make a bracket ore something to hold the plastic back, but realy dont know.
I cam also get some new shackel in the back of the leaf spring, that will giv me even 1 1/2" nore lift.
But do not know if that will bee ok after that
Norwegian Viking
(from Norway)
post #6 of 11 Old 11-24-2007, 12:56 PM
Raul@Stealth Automotive's Avatar
you sure its rubbing on the plastic and not on your leaf springs? i had the same size tires except with 17" wheels and mine would rub on my leafs... but i also had a 3.5" shackle/hanger kit on
Raul@Stealth Automotive is offline
post #7 of 11 Old 11-24-2007, 01:40 PM Thread Starter
Jupp i am sure its not rubbing on the leaf, i have plenty space to the leaf, its the plastic that is rubbing 100%.
My lift is 2", but can get 1 1/2" more whit new shackels.
Norwegian Viking
(from Norway)
post #8 of 11 Old 11-24-2007, 01:47 PM
i would get the shackles and lift it the extra 1.5"
post #9 of 11 Old 11-24-2007, 01:54 PM
jamstoyz's Avatar
nothin a dremel tool cant fix. my friend has a xcursion and he cut the plastic out of the rear of the fender. just a few inches up from the bottom. it dont look bad. can hardly tell. but it solved his rubbin problem.
05 Single Cab Short Bed
*03 Turbo*Stroked Injectors*AFE Stage 2*Small mouth Intake*SCT With Eric's Extreme Race*4.30 Gear*Best ET 13.5@99MPH*
jamstoyz is offline
post #10 of 11 Old 11-24-2007, 02:33 PM
I am sorry I miss read your posting. I thought you meant the back tires were rubbing also. That is what made me think it was the backspacing of the new rims.
But you were saying that the back of the front tires by the wheel well is what is rubbing as well as the front of the tire. I am sorry for my confussion on this.
2002 7.3L burnt
