Tires Vs rim size help!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-21-2007, 12:18 AM Thread Starter
03-6.0PSD's Avatar
Send a message via MSN to 03-6.0PSD
Ok well im sick of my BFG all terrians 37x12.50xR20
I have found a tire I really like. the Procomp 3ply X-terrian Radials in the 38.50x14.50xR20
Now my problem is that my rims are only 8.5 wide (eagle alloys 178), and it says I need a 9''-12'' rim.
I dont haul alot if any. nothing over 5000lbs. and very rarly.
So will this be a problem? I have been told I cant go bigger then a 13.50 wide.
I dont see why it would be a problem to drive around town like that. but any help or advice would be great. Thanks
2006 F-150 5.4L Lariet Crewcab 5.5 box Black on Black fully loaded 4x4
No Longer: 2003 6.0 PSD F-350 EXT Cab, Longbox, 4X4, SRW
SCT Xcal3 From DJ's
AEM Brute Force Intake
MBRP 4'' Turbo Back w/ Muffler and Cat Delete
Dual Pod with Silver Faced Stewart Warner Gauges Boost and Pyro
High Idle Mod
8'' Lift
37'' Tires
20'' Mags
Chrome Handles and Mirrors
Billet Grill
03-6.0PSD is offline
post #2 of 4 Old 11-21-2007, 02:42 AM
You probably can run 14.5's on 8.5 rims, but it has been my experience that the center of your tires will wear quickly and the truck will wonder on the road.
BIG COUNTRY is offline
post #3 of 4 Old 11-21-2007, 05:38 AM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Feedback Score: 4 reviews
x2 and I'd be interested in the offset of your tires because you are gonna have 2 extra inches on the inside and it may just be enough to rub on your leafs...
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 4 Old 11-21-2007, 08:42 AM
monster energy's Avatar
Your tires will wear fast in the center of the tread just like running to much air
monster energy is offline
