How do you get moisture out of headlights? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-18-2013, 07:26 AM Thread Starter
drmisherre's Avatar
Send a message via AIM to drmisherre
I just bought some eagle eye harley lights for my truck the other week and I have moisture in the already. The company I bought them from said I need to try and get the water out of them before they'll warranty them. They said to leave the headlights off the truck in sun for 48-72 hrs. I don't know about you but I need to my to drive everyday. Has anyone found a way to accelerate this process? I remember ready people but headlights in the oven on cardboard to melt the glue to pull the lenses. If I put the oven at like 100 degrees, do you think that would be safe enough to put them in there to accelerate the drying?
Sent from my iPhone using AutoGuide.com App
2000 ford E-350 superduty: SOLD
95 f-250 94k original miles!: SOLD Also
Early 2004 Ford f-250 Lariat:
94 12v!
ARP studs
HX35 turbo
Pump tweaking
4" straight pipe to 5" tailpipe
drmisherre is offline
post #2 of 11 Old 01-18-2013, 07:55 PM
Maybey try some rice. I knowthat rice will dry out a cell phone that has gotton wet. It might work. Throw some white rice in there. I am not crazy!!!
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #3 of 11 Old 01-18-2013, 07:57 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
BUY True OEM, not knock offs!!
2000-7.3L is offline
post #4 of 11 Old 01-18-2013, 08:10 PM
dieselmatt's Avatar
Quoted: 4 Post(s)
You could put them in the oven, but if you leave them in too long you will need to make sure they are back together completely because the seal will soften. The oven route is usually how people take headlights and taillights apart.
dieselmatt is offline
post #5 of 11 Old 01-18-2013, 08:27 PM
Mud digger's Avatar
What I've always did was to drill a small 1/8" hole in the bottom of the housing where you can't see and that allows the moisture to escape easily and won't allow dirt and other crap to get into the housing. works great!
David
2004 F-250 CCSB 4x4- Sinister Coolant filtration system, CCV reroute, 5" Flo-Pro Exhaust with a 6" MBRP tip, SCT Livewire TS
Mud digger is offline
post #6 of 11 Old 01-19-2013, 05:49 AM Thread Starter
drmisherre's Avatar
With a hole in the bottom, I'd be worried about moisture getting and in and rode debris, such as dust and salt. You don't have that issue?
94 12v!
ARP studs
HX35 turbo
Pump tweaking
post #7 of 11 Old 01-19-2013, 03:02 PM
Mud digger's Avatar
Not at all
David
post #8 of 11 Old 01-20-2013, 04:21 PM Thread Starter
drmisherre's Avatar
Well I put them in the oven for a few mins, rtv'd them and drilled a hole so hopefully they'll be good To go now
94 12v!
ARP studs
HX35 turbo
Pump tweaking
post #9 of 11 Old 01-21-2013, 07:54 AM
Aretoo's Avatar
Take the bulbs out and take your wife's hair dryer out there and blow some warm air in there. Did this the other day to my buddies car who was having the same problem. Dried it right up and he has not had a problem since.
Hello, my name is Nathan...and I am addicted to my skinny pedal!
2006 F250 Crew Cab Short Bed
Harley Davidson Edition # 01592
MODS
ARP Studs
Edge Insight CTS with EGT
IPR Gen2 EGR Delete
Sinister Coolant Filter
MBRP 4" turbo back
PHP Atlas 40 FICM Tune
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #10 of 11 Old 01-21-2013, 08:32 AM Thread Starter
drmisherre's Avatar
We'll see if it comes back after what I just did. If it comes back then I will.
94 12v!
ARP studs
HX35 turbo
Pump tweaking
