Rough Ride - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-21-2012, 04:20 AM Thread Starter
Question Rough Ride
So I just put on new billstein shock's leveled my truck & put on new 35" nitto terra grappler's. I also had my front end completely rebuilt, problem is the truck rides and handles like crap now is there anything I can do to make it handle and ride like it used to or atleast close?
sampson2269 is offline
post #2 of 17 Old 12-21-2012, 04:32 AM
Quoted: 58 Post(s)
Would help to know some details so we can assist: what year truck? 03s and 04s are leaf spring front end and 05 - 07 are coil spring. Which line of Bilstein shocks? Lastly, what do you mean by "rides like crap"?
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 17 Old 12-21-2012, 04:44 AM Thread Starter
It just rides really rough I can feel every single bump now, reason i'm complaining about this is I'm on crappy dirt roads every day for work. And what I mean by it handles like crap is it just feels like its tough to steer while going down the highway it feels like it's drifting left or right all the time.
2005 King Ranch FX4 F250
Toyo Trail Grappler, 35x12.5 R18LT
Billstein 5100’s
Daystar 2” Leveling Kit
S&B CAI
MBRP 4” Turbo Back
MBRP Oversized Cat
Aero 4040 Muffler
ARP Headstuds With ONYX Headgaskets
Bulletproof Egr Cooler
NUC Oil Bypass
IPR Coolent Filter
Bluespring Upgrade
Edge Insight Cts
SCT 9600
IDP Tunes: Xtreme Street,Street,Tow
Quick Trick: Wild Looney,Street
PHP Gryphon - Atlas 40
High Idle Mod
post #4 of 17 Old 12-21-2012, 07:27 AM
rr06psd's Avatar
Most people will say 5100's are a good choice. I had them and had same issue as you. I put rancho 9000's and like the way they ride. Have about 70,000 and still doing good.
Sent from my DROID RAZR using AutoGuide.Com Free App
2006 F-250 Lariat FX4 CCSB
BPD EGR Cooler
BPD Oil with cold Weather
Amsoil Bypass
Baldwin Coolant Bypass
Insight 1st version
SCT Matt's 8000 tow
Gryphon on Atlas 40
Banks Technicooler
Silverline 4'' turbo back
Updated ford parts
Arp's at 126,000
rr06psd is offline
post #5 of 17 Old 12-21-2012, 01:15 PM
Dumb question, but did you check the tire pressure? I have had new tires put on and they'll put 80 psi in a 50psi tire. Also are u new tires E rated or D rated?
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #6 of 17 Old 12-21-2012, 06:47 PM
shawnb99's Avatar
THE 5100 is a firmer shock, look at tire pressures, and use a little more speed when traveling rougher roads, let the shock start to work,.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #7 of 17 Old 12-21-2012, 06:54 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I bet if you check your tire psi its to the max. the "use a little more speed" on a rough road is a bad idea....lil dangerous imo.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 17 Old 12-21-2012, 08:10 PM
USAFBowman's Avatar
Have you upgraded to dual steering stabilizers when you bumped the tires up to 35s?
USAFBowman is offline
post #9 of 17 Old 12-22-2012, 05:34 AM Thread Starter
No on the dual steering stabalizers, haven't checked the tire pressure yet. What do you guys recommend? It's just for work I won't be pulling anything so I can probably get away with the minimum huh?
post #10 of 17 Old 12-22-2012, 05:38 AM Thread Starter
Will those dual steering stabilizers make it handle better?
