issues with 05 headlight conversion - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-18-2012, 01:41 PM Thread Starter
I bought the generic Ebay Harley style headlights to put on my black 03 F250. I bought the H13 bulbs, and the conversion harness.
Problem 1:
Conversion harness and H13 bulb have the same end, meaning there is no way they will connect.
Problem 2:
H13 bulb will not fit in the hole, and if it did, it wouldn't spin and lock in place because the bulb doesn't have tabs on it.
Am I missing something???
ID:	47199   Click image for larger version
~Kerri
03 f250 lariat supercab
05 6.0 motor, studded, egr delete, coolant filter
5" exhaust, k&n intake, sct tuner, insight monitor
DSMissed is offline
post #2 of 7 Old 12-18-2012, 01:45 PM Thread Starter
Ok, I may have just figured it out. The guy sent me 9007 bulbs instead of 9008. I'm an idiot. Sorry.
~Kerri
DSMissed is offline
post #3 of 7 Old 12-30-2012, 06:53 AM
Ok I'm trying to do conversion myself. Are you saying that I can not just use my STOL harnes with 9007 bulbs because they won't lock into headlight assembly? So h13 harness and 9008 bulbs are a requirement? Thanks
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
post #4 of 7 Old 12-30-2012, 07:01 AM
yes you need the h13 harness- mine just has the h13 plug with 3 wires- i just soldered them to factory harness, shrink wrap and plug into the light
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 7 Old 12-30-2012, 09:30 AM
Ok thanks. So you cut the old plug off then?
Amfw119 is offline
post #6 of 7 Old 12-30-2012, 04:12 PM
yup, and wire to corresponding colors
bpd
Warren comp trans
04cr450 is offline
post #7 of 7 Old 12-30-2012, 04:14 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
You can buy a conversion plug for $40 or so and not cut up your factory wiring.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
