Upgrading to Harley's and HIDs,what do i need? - Ford Powerstroke Diesel Forum
Old 12-14-2012, 07:23 PM
Send a message via AIM to drmisherre
Looking to upgrade my 04 headlights to 05+ Harley's and also want to do HIDs, what part of the harness do I need? I know if you want the full benefit of the new lights is the brightness. With HIDs going in, what parts do I need to upgrade and what will the HIDs replace?
Sent from my iPhone using AutoGuide.com App
Old 12-15-2012, 03:58 AM
DDM Tuning. Get the 55watt high low beam hid kit with harness. Like $80
Old 12-15-2012, 06:33 AM
you will also need to cut your header panle for the harley lights to fit. they mount a little different. it is easy to trim being it is fiberglass. you will cut one of the stock 04 mounting tabs off.
Old 12-15-2012, 07:08 AM
I do remember all that, I just haven't been able to find info on what parts I need from the 05+ harness. I've read I shouldn't put 55w in my fogs because of the heat issue correct?
Old 12-15-2012, 09:58 AM
I have 55w in my fog lights. i use them everynight. No problem with heating. In fact hid bulbs burn cooler than regular bulbs.
