Amp BedStep 2 Install w/pics! - Ford Powerstroke Diesel Forum
post #1 of 19 Old 12-07-2012, 07:39 PM Thread Starter
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
So I picked up an Amp Research BedStep 2 for an early Christmas present and I'd figure I'd share the install with you all. It was super easy to install and everything you need came with the kit.
First, set everything up on the tailgate; Check!
You have to pre-assemble it before you bolt it up to the truck.
Next, you put the metal bracket into the channel of the bed. It fits perfectly!
Then you get the unit you pre-assembled and bolt it to the bracket in the channel of the bed. But you can't tighten them down yet because you still need to adjust the whole unit.
Mount the step pad to the unit and line it up with the bed.
The hardest part of the whole install is having to drill a 1/2 inch hole in the body mount bracket, but my awesome Porter-Cable drill punched through in less than a minute!
Then mount up the final bracket and tighten all of the bolts.
Finally, step back and admire your handy work, then take a crappy cell phone pic for all to see; Check!
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #2 of 19 Old 12-08-2012, 05:07 AM
poorboy1964's Avatar
Quoted: 2 Post(s)
Good wright up, those steps are great. gotta say i think you have one of the best looking truck on here
Tom
2003 CCSB 4X4 6.0 Born on 5/03 Tuned by Vivian, 4" Turbo Back Exhaust, Edge CTS w/EGT, Coolant filter. ELC. fuel pressure gauge,
2002 SCLB 4X4 7.3 Stock
poorboy1964 is offline
post #3 of 19 Old 12-08-2012, 06:39 AM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Hmmm, one of those would help me look in the tool box.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #4 of 19 Old 12-08-2012, 06:58 AM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
Looks good Denis.
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #5 of 19 Old 12-08-2012, 09:00 AM Thread Starter
dfuzz78's Avatar
Well thank you! It's come a long way and it will never be complete.
Originally Posted by westcoaststrokin View Post
Looks good Denis.
Thanks Josh
Denis "Lt. Sled"
dfuzz78 is offline
post #6 of 19 Old 12-08-2012, 09:56 AM Thread Starter
dfuzz78's Avatar
Some daytime pics.
It's not that noticeable, now what is noticeable is all of the dirt!
Denis "Lt. Sled"
dfuzz78 is offline
post #7 of 19 Old 12-08-2012, 01:11 PM
southend's Avatar
Nice writeup, looks good.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #8 of 19 Old 12-08-2012, 02:06 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
dfuzz, is your truck lowered?
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #9 of 19 Old 12-08-2012, 02:29 PM
Quoted: 365 Post(s)
Feedback Score: 5 reviews
Looks great!!!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #10 of 19 Old 12-08-2012, 02:49 PM Thread Starter
dfuzz78's Avatar
Nope, it's a 2wd that is leveled, with 33" tires.
Denis "Lt. Sled"
dfuzz78 is offline
