| 6.0L Exterior Discussion Body and Accessories Talk |
Door adjustment
hello all
06 extended cab 4 door and i have noticed that shutting the door u have to slam it..the body lines are in great shape so my suspect is the door latch..? is do i have to pull panels inside to adjust? Jeremy |
No, it's just a couple Torx head bolts you loosen off and can slide the latch out just a touch. Be careful not to go too much or your door won't seal completely and you can get road noise/water leaks.
