Messed up leafs? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-25-2012, 07:29 PM Thread Starter
06 Strokin's Avatar
Messed up leafs?
So while I was getting new tires put on today I was looking at my brakes and rotors and then I saw the rear leafs. Have these been overloaded? Are they still ok? They just don't look right to me. what do yall think? Thanks, Barron
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
upgraded stc fitting
Cat ELC,
coolant filter
EGR delete
Reman tranny 126,xxx
06 Strokin is offline
post #2 of 5 Old 10-25-2012, 07:41 PM
ZMANN's Avatar
Quoted: 1894 Post(s)
don't sweat it they have a weird arch pattern and ford puts shims in the top plate area all the way through the spring pack
look for cracks and the lower overload leaf looks a little cut on one end does the opposite look the same ? I would check mine but I have since moved on and sold the stockers
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #3 of 5 Old 10-26-2012, 03:58 PM
2006oilburner's Avatar
i looked at mine and they have a nice curve to them, you might want to look for cracked springs especially behind the u bolts, those springs look like they have been overloaded alot, just my 2 cents
2006oilburner is offline
post #4 of 5 Old 10-26-2012, 04:55 PM
JSchuricht's Avatar
That's not right, start looking for new springs.
JSchuricht is offline
post #5 of 5 Old 10-27-2012, 12:10 AM
snafu!'s Avatar
I wouldnt worry about new leafs unless they are cracked. When I was working my way through college I worked as a roustabout and all our trucks had gin poles on them. We would pick stuff up that would just barley leave the front tires on the ground. You would have to back up several times to make it around a corner because the front tires would skid. Their wasnt a truck in the fleet that the rear leafs weren't bent. The only thing that it will effect is ride height.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
