06 F250 Lift Kit back to Stock? - Ford Powerstroke Diesel Forum
Old 10-24-2012, 05:01 AM
Exclamation 06 F250 Lift Kit back to Stock?
Helping my my buddy figure this out, Hes got an 250 with a 6" lift on it. Wants to bring it back to stock height and trying to figure out what he needs to get. Know that he needs to get new front springs and shocks, and in the back get new u-bolts and blocks. Anything else im missing? I would take a picure of the lift, but his truck isn't here. Any input helps
Old 10-24-2012, 05:18 AM
Almostdunfukinwidit
Is the OEM track bar on the truck?
Old 10-24-2012, 05:46 AM
Couldnt tellya, only looked at the truck for a second
Old 10-24-2012, 08:41 AM
Will probably need the stock pitman arm for the steering box. Don't forget to remove the shims out of carrier bearing as well.
Old 10-25-2012, 05:56 PM
look online for the brand lift he has to see what all was swapped, im sure it will need pitman arm, stock trac bar mount, remove carrier shim, radius arm drops, brake lines or drop brackets, springs shocks and blocks maybe even add a leaf
