first post sealed beam headlight ? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-18-2007, 06:44 PM Thread Starter
edit sorry this should be in 6.0
just got an 03 4x4 reg cab work truck edition with the stupid sealed beam head lights. I am about to upgrade to 06 style bumper n grille. My question is what is the process of getting the 06 composite headlights to work? I have found the picture with the template to cut out to change from 03 composite to 06, Is this the same for the sealed beam version? '05 Head Light Conversion Template/Guide For Cutting
since you guys are way ahead of me on upgrades, I will be needing
06 chrome bumpers front and rear
06 grill
headlights
leveling kit-- I think im am going with the $400 kit I saw in a thread here
a set of wheels n tires 20"
If anyone has any of these i would be interested.
I have been browsing on the forum for a while and already appreciate the information I have learned
Thanks for the help,
df
inprogress2 is offline
post #2 of 13 Old 10-19-2007, 09:56 AM Thread Starter
noone knows?
post #3 of 13 Old 10-21-2007, 06:42 AM Thread Starter
ANy help appreciated greatly
post #4 of 13 Old 10-21-2007, 06:28 PM
I have no idea if the sealed beam is the same as the composite -- would have to look at the mounting panel that that template is cutting to see if they are the same -- if they are, you should be good to go..
otherwise, if you're already spending the money to do the conversion, just by the headlamp mount panels for the 05-07 lights instead of trying to cut yours...
Blue01F250 is offline
post #5 of 13 Old 10-21-2007, 06:35 PM
Desert Shield/Storm Vet
vitalidle's Avatar
This might help you King Kustoms of Temecula,CA - "Two Thousand & FIVE" Truck!
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #6 of 13 Old 10-21-2007, 06:41 PM
Raul@Stealth Automotive's Avatar
good info .....
Raul@Stealth Automotive is offline
post #7 of 13 Old 10-21-2007, 06:45 PM
vitalidle's Avatar
Would like to do it myself, but I have a feeling Im going to be buying my dads 06 next year.
Auto 93,000 miles
DP Tuner F5
post #8 of 13 Old 10-21-2007, 06:56 PM
Well when you do Vit -- sell me some of the 7.3 mods!
*cough* turbo mods *cough*
post #9 of 13 Old 10-21-2007, 06:58 PM
vitalidle's Avatar
You have first crack my friend as everything will probobly go back to stock with my truck other then the gauges and exhaust
Auto 93,000 miles
DP Tuner F5
post #10 of 13 Old 10-21-2007, 07:08 PM
haha, sweet! cause I doubt I'll ever get a new turbo (specially since I have PMR's )
