New badges - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-18-2007, 05:36 PM Thread Starter
New badges
thanks to a tip from a fellow powerstroker(wrs8574) I finally found the international badges i have been looking for. Getting ready to order them tomorrow. T 444E* VT 365* International Domed Labels
The VT365s of course. But does anyone have some helpful suggestions to remove the old ones and to prep and place the new ones?
holleywood is offline
post #2 of 13 Old 10-18-2007, 05:43 PM
sawyer1's Avatar
Those look sweet Im getting them now, cant wait to get the old 7.3l ones off. Maybe some one will know how to pull the old badges off.
-Sawyer-
USAF COP!!
2000 F-250 Lariat, 142,000mi automatic trans.
SOLD SOLD
New rig 2006 dodge cummins mega cab
sawyer1 is offline
post #3 of 13 Old 10-19-2007, 05:21 PM
Those are nice! I thought the 7.3's were 444???
and to get them off -- all you have to do is run a razor around the edge to slice some of the tape and then just peel them off.. just be careful while doing so in case they try to take some paint with them -- but usually, you shouldn't have that problem
Blue01F250 is offline
post #4 of 13 Old 10-19-2007, 05:27 PM
DoubleDpsd's Avatar
razor sounds dangerous. I recommend fishing line or a credit card. After I got them off I put a rubber wheel drill bit on the drill and buffed the sticky stuff off then hit it with some cleaner wax.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #5 of 13 Old 10-19-2007, 05:45 PM Thread Starter
The 7.3 are 444. But i have an 05 so i gotta go with the 365. I think a have some fishing line downstairs might try to take them off tomorrow
post #6 of 13 Old 10-19-2007, 06:04 PM
Yah, if I would have payed attention to the forum this was in.. I would have known that!
I basically went by your pic and didn't look at it that well
post #7 of 13 Old 10-19-2007, 06:27 PM
powerstruck's Avatar
use a heat gun and a credit card, mine peeled right off.
2003 F-250 4WD EXT CAB
EBPV delete
turbonetics BB turbo
4" mbrp straight pipe turbo back
volant cold air intake
ts-6 chip
egt, boost, fuel pres. guages C2
aih delete
fuel regulator shim kit
hpx-over
zoodad
amsoil by-pass oil filter
coolant filter
4" superlift
315/70/17 BFG a/t
bilstein shocks 5100
*southbend clutch next on the list
powerstruck is offline
post #8 of 13 Old 10-19-2007, 07:17 PM Thread Starter
sounds like i have a job to do that and my fuel filter tomorrow. Did my Zoodad mod last saturday. I love these cheap/freebee mods!!!!!
post #9 of 13 Old 10-20-2007, 10:56 AM
go get some goo-gone. stuff is godly!
Stroker49 is offline
post #10 of 13 Old 10-20-2007, 02:30 PM Thread Starter
just finished taking them off. Thats some sticky stuff. But i found some Goo-gone gel, and i let it soak for 5 mins, With a little rubbing came off in about 5, cant even tell they were there. Execpt for my neighbor came over and asked if i did an engine swap because it didn't say diesel on it. Hahah
