grill?? - Ford Powerstroke Diesel Forum
Old 10-12-2007, 02:25 PM
grill??
I have on 04 6.0.Can you change the 04 grill for an 05-07 grill, no lights no bumper just the grill???????
Old 10-12-2007, 02:27 PM
yes, trim the bottom of the newer grill about 1-1 1/2 inches i think, try to locate some grills on EBAY, this one guy does it by milling it down to size, making it direct bolt on.
ADMIN AND TECH
will not fit without bumper swap, unless you want to cut on it of course
Old 10-12-2007, 02:35 PM
well, that was about 5 mins of shopping, anyways..
here it is..
eBay Motors: CHROME FORD SUPERDUTY GRILLE F250 F350 SUPER DUTY GRILL (item 150169925486 end time Oct-14-07 11:45:00 PDT)
Old 10-12-2007, 02:41 PM
yah, you have to cut it and the bottom will be shorter than the top
or you can put the different bumper on which has a deaper center section and put the full grill on it
Old 10-12-2007, 05:40 PM
Semi-related,
-Can you leave the 04 bumper and grill and use 05 and newer lights?
Old 10-12-2007, 05:47 PM
yes -- you either have to cut the headlamp header panel, or buy the panels and lights for each side
like this... '05 Head Light Conversion Template/Guide For Cutting
