| 6.0L Exterior Discussion Body and Accessories Talk |
2.5 level questions
Anyone running a ready lift 2.5 level?
Did you get trac bar? What size tires did you fit ima be running the king each 18s.. Or do y'all suggest another leveling kit? Any good deals online? Thanks |
I installed a 2.5 leveling kit about a month ago.
It contained a couple what I would describe as little leaf packs and four u bolts. It cost around $100 on amazon. If I remember they came from Custom Diesel. The install was easy. No issues. I run 305/70/16 on the factory rims. Sent from my Autoguide iPhone app |
Did you put a block in the back to raise it a inch?
Ya I have the 16s now but bought the 2004 18s king ranch rims. Prob gunna run 33 toyos. Did u ever add a trac bar? |
I have an F350 so the back end was already much higher than the front.
After I installed the blocks it was perfectly level. I run the Toyo open country ATs. Sent from my Autoguide iPhone app |
All terrains??? What size
Bumpppp bumppppppp
If I remember correctly, they are 305/70/16 10 ply. I would go look but I'm in Brazil at work. But I'm pretty sure that's the size.
