oversized tires - Ford Powerstroke Diesel Forum
Old 07-12-2012, 03:03 AM
oversized tires
I have an 03 f350 4x4, and was wondering what is the largest tires i could put on the truck without any issues, i dont want to jack it up or cut fenders or anything, just want to know what size tires i can slap on my stock truck. thanks
Old 07-12-2012, 04:58 AM
I ran a set of 285x75R18 Toyo Open Coutnry At's on my truck at stock height and they rode great and never rubbed. I still run the same tires with a 4.5" lift and they still look good. They don't stick out the side of the wheel wells. Over all I think that they are a 11" wide 35. I get good wear out of them also, 35-40k
Old 07-12-2012, 05:31 AM
Send a message via AIM to FastFocus
i ran 315/70r17's in BFG A/T before i put my leveling kit on, no rubbing at all.
i think on a stock truck, with no lift 33's look the best though. i had 285/70r17's first in the same tire and the 315s almost looked too big. I think it would have looked better with the 2.5" leveling kit i have now.
Old 07-12-2012, 07:13 AM
My Excursion had 325/60-18 Terra Grapplers on it when I bought it. They rubbed the leaf springs a little, I never noticed it in the steering wheel. I pulled them off and put on 295/70-17's Hankook Dynapro ATM's and have no issues.
Old 07-21-2012, 02:23 PM
I would prefer to keep the tire size 16 though, i like my stock rims, i just want to oversize them as much as possible on 16's
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 07-23-2012, 02:52 PM
285/75/16 are a good fit with no lift, plus just about every manufacturer will offer this size in both an all terrain and mud terrain so the selection is huge. 305/70/16 will also work and will give a slightly wider stance, but you won't find the tire selection compared to the 285's. Good luck!
Old 07-23-2012, 04:05 PM
I was just giving you the sizes that I know can work. You can toss them in a tire size calculator and find something comparable in a 16.
Old 07-24-2012, 03:00 AM
Alright cool, thanks. I will definitely look into that
Old 07-25-2012, 06:49 PM
Here is a easy to use Tire Size Calculator. It will come really close to what the tire size will be, just be sure to check with the tire manufacturers website to get exact specifications for the tire you are considering. Manufacturers vary a little bit from each other for the same size tire, especially when you are looking at metric sized tires.
Cheers,
Brew
