wheel size - Ford Powerstroke Diesel Forum
Old 10-08-2007, 02:52 PM
wheel size
i just ordered the rize 8inch lift for my truck and when i was ordering tires i decided to go with the toyo open country mt 38x15.50 with 20 inch rims the place that i ordered it from said it would be ok to run a 10inch wide wheel does anyone have any experience with this and think i should go with a wider wheel
Old 10-08-2007, 02:55 PM
IU Hoosier Fan
well I hate to tell you but I say your gonna rub a little bit cause I have a 8'' lift also but on 37's... and I rub a little if I turn it as hard as I can..
Old 10-08-2007, 02:57 PM
not too worried i'll do some trimming if it does
Old 10-08-2007, 03:10 PM
IU Hoosier Fan
okay just wanted to let you know that is what I did....
Old 10-08-2007, 03:11 PM
how much did they charge you for the new gears?
Old 10-08-2007, 03:13 PM
IU Hoosier Fan
well at the same time I had the lift, gears, and limited slip put on and total it was around $1200... sorry can't really recall... but I love haven the 4.56's... you can tell I do have bigger tires on but not that much from stock..
Old 10-08-2007, 03:20 PM
they told me it would be 1000 an axle for 4.88 gears
Old 10-08-2007, 04:03 PM
IU Hoosier Fan
well first off I wouldn't go with 4.88's... the 4.56's are great for your size of tire your gonna have.... and that is just outragous... go find someone else and ask around... I didn't do any of it myslef cause where I could have done it my uncles grarage burned down... :-( sooo... I just payed someone to do it... and does that include any different kind of limited slip??
Old 10-08-2007, 04:18 PM
i think he wont rub because he does not have front leaf springs.... and yes you can run 10" wide wheels with no problem.... your gonna love that rize kit.... check this puppy out... drove it this weekend.... it has a 8" rize kit on 20x10" wide wheels on 37's and i turned it all the way with no rubbing......
Old 10-08-2007, 04:20 PM
oh and 1k an axle sounds about right... remember the gears alone cost around 500 bucks and they are charging you 500 bucks for install which is the going rate..... also if you have the extra funds put a locker in the rear like a detroit... you wont be disappointed....
