| 6.0L Exterior Discussion Body and Accessories Talk |
Will 35's fit my 06 250
hey guys i just picked this truck up 06 with 42k 6.0 4x4 in mint shape. i no there is a 2 1/2 leveling kit on the front and i think the same in the rear bc it site little higher then stock i belive. i have nitto mud grapplers 33/12.50r18 on it with lots of room. also has 18inch xds on it. you think i can clear some 35's
Yes without a doubt. I have an 06 with a 2.5 leveling kit and I clear 35s just fine. Had to trim the plastic peice under the front bumper but they clear just fine.
i had 35's on my 06 and they fit fine stock but i think mine had f350 suspension from the factory
i have an 04 with a 2 inch leveling kit in the front and the only trouble i have is a little rub around sharp turns
My 05 is stock height with 325-65-18 35-13.50-18
You might check on the back spacing and rim width before you put 35s on. It will rub if you have less than 5" of back spacing and a rim wider than 9", it is also recommended that you go with a tire that is 12.5 wide. Mine has 18x10 with 4.5" of backspacing and 325/65R18 and they rub when I'm turning at bump, the wheels and tires were on the truck when i bought it. I am now looking for a 4 inch lift to clear this package.
