A much needed facelift - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-31-2012, 08:27 PM Thread Starter
tractorjoe's Avatar
I finally got around to some of the things I have been wanting to do to my truck that I bought in January.
Recent mods include:
Muffler delete
Smoked cab lights
Rear slider window
Replacement side windows (deep scratches)
Window tint
2.5" leveling kit (home brew)
33.5" tires LT295/75R16 BFG A/T
Stereo.
Tell me what you think. Next to come is some body work.
Name:	IMG139 [640x480].jpg
ID:	38598   Click image for larger version
Name:	IMG202 [640x480].jpg
ID:	38599   Click image for larger version
Name:	IMG204 [640x480].jpg
ID:	38600   Click image for larger version
Name:	IMG205 [640x480].jpg
ID:	38601   Click image for larger version
Name:	IMG208 [640x480].jpg
tractorjoe is offline
post #2 of 7 Old 06-02-2012, 10:33 AM
southend's Avatar
Looks nice, shocks look like chit, how hard were the cab lights? :thumbup:
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 7 Old 06-02-2012, 06:53 PM Thread Starter
tractorjoe's Avatar
Hey Thanks, I know the shocks need replacing. Not sure which shocks to replace them with. Any suggestions? No off-roading, just hauling my 20' gooseneck cattle trailer and back and forth to work.
Cab lights should have been easy except i lost the instructions and decided to improvise. I drilled a 1/2" hole (supposed to be 7/8")for the pigtail and had to modify the rubber socket to fit in the hole. Also the screws that come with the kit (RECON) are really cheap. I stripped about half of them before i gave up and got some stainless screws from the home depot.
post #4 of 7 Old 06-02-2012, 08:33 PM
southend's Avatar
Good info on the lights, did your truck already have the harness installed? I put bilstien shocks on mine, not sure which ones. They seem ok to me, but I don't have experience with anything else. Oh, you better get a monitor on that truck if you don't already have one.:thumbup:
southend is offline
post #5 of 7 Old 06-03-2012, 05:14 PM Thread Starter
tractorjoe's Avatar
The harness was already in the passenger kick panel, everything else came with the kit.
What is the cheapest best monitor to run on the 6.0?. I just bought this truck and I've noticed a few things under the hood like the left head gasket is new, turbo looks new and the Egr valve is unplugged?? Truck is at 300,000 km.
post #6 of 7 Old 06-04-2012, 05:15 AM
southend's Avatar
I only have experience with edge cts, it is great. You just have to spend extra money for fuel pressure and egt. I think fuel pressure is important, egt only if you haul alot. It will display up to 8pid's at once. do a quick google search, there are cheaper options, all are worth their weight in gold. If your egr is unplugged, you probably have an egr cooler delete already, that is good.:thumbup: don't waste time, get a monitor.
southend is offline
post #7 of 7 Old 06-04-2012, 05:26 AM
southend's Avatar
Just found this, about egr delete. Check it out.
http://www.powerstroke.org/forum/sho....php?p=3101465
southend is offline
