Harley Davidson Light install ?'s - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-14-2012, 07:44 PM Thread Starter
unsane19's Avatar
Ive been searching the site and cant seem to find anything that helps. Has anyone done a write up on an install for these? I have a 2004 250 and have seen it done with some trimming. Any help would be great.
04 6.0 crew cab short bed
6" fabtech
37x13.50x17 toyo mt's
Bullydog w/outlook monitor
FBD 4" straight pipe
S & B intake
unsane19 is offline
post #2 of 9 Old 05-15-2012, 06:47 AM
Not to be mean, but your search skills are lacking
'05 Head Light Conversion Template/Guide For Cutting
That thread is currently on the first page of this sub-forum.
Boreal is offline
post #3 of 9 Old 05-15-2012, 06:28 PM Thread Starter
unsane19's Avatar
well thats what i get for useing my computer at work. thanks for the help.
6" fabtech
S & B intake
unsane19 is offline
post #4 of 9 Old 05-15-2012, 09:32 PM
Good luck! I have a set of HD headlights ready to go on my '04 as well, but I'm nervous to start trimming the header panel. Let us know how it goes.
Boreal is offline
post #5 of 9 Old 05-18-2012, 11:29 AM Thread Starter
unsane19's Avatar
i havent got the ok from the financial advisor just yet haha, but within the month ill have a set. where did you get yours if you dont mind me asking.
6" fabtech
S & B intake
unsane19 is offline
post #6 of 9 Old 05-18-2012, 11:53 AM
RTR stroker's Avatar
I did the headlight swap and it was super simple. I found the template on here and followed it and they fit great. Good luck
T.J.
- 2004 F250 FX4 crew cab -
* 4" MBRP straight pipe TB 5" tip
* "blue spring" upgrade
* 6.4 banjos
* A pillar triple gauge pod (egt,boost,trans temp)
* 2" leveling kit
* 35" yoko's
* 05' headlights(soon to be front end)
* 08' Taillights
* CCV reroute
* EGR Delete
* Sinister coolant filter
* Riff Raff boots
* Rotella T6
RTR stroker is offline
post #7 of 9 Old 05-18-2012, 12:03 PM
DoubleDpsd's Avatar
This mod is pretty easy. Kinda hard to eff up. You could jump into it without a template, something you can eyeball.
Sent from my droidx using autoguide app
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #8 of 9 Old 05-21-2012, 12:01 PM
I picked up mine off of ebay. They were about $160 for the pair and that included the little pigtail adapter. I don't like to cut and splice
Boreal is offline
post #9 of 9 Old 05-24-2012, 03:04 PM
Harley Strokin''s Avatar
You can also buy the 05-07 header panel on ebay too, thats what I did when I did the conversion in my 2000. Its a little more pricey and if your keeping the 99-04 grill and bumper there are a couple of minor fitment issues.
05 6.0 H.D. Edition, Studs, Delete, SCT.
Harley Strokin' is offline
