Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
  #31 (permalink)
Old 12-08-2008, 03:54 PM
RocKrawler RocKrawler is offline
One of the guys on e-bay offers the adapter harness along with the lights for under $200 with either the chrome or black housing. I was going to go this route myself but after hearing how bad the lighting was after the swap I decided to order the clear 99/04 housings and clear markers - IMO looks just as good & more bulb selections
  #32 (permalink)
Old 12-08-2008, 05:21 PM
CCSBD CCSBD is offline
I thought it was brighter with the swap? The new lights pull more watts or amps or whatever right?
  #33 (permalink)
Old 12-08-2008, 05:33 PM
I searched & read a lot of people saying the new setup needs a relay harness to run higher power bulbs, they still werent as bright as better bulbs in the earlier clear housings - kinda makes sense to me as the 05 housing has the tiny, narrow reflector compared to the bigger housing on the earlier setup.
  #34 (permalink)
Old 12-12-2008, 06:52 AM
BamaSixGun BamaSixGun is offline
Originally Posted by asu20 View Post
hey guys, i just ordered a set of the 05+ harley headlights for my 04. I see dfuser offers the wiring harness conversion with the relays, I'm just wondering who else offers them. TIA
I would not hesitate to order from Bob at dfuser. If you call him up, he answers and is more than willing to help out. No need to shop around IMHO.
  #35 (permalink)
Old 12-21-2008, 01:47 PM
7.3powerstroke2000 7.3powerstroke2000 is offline
Great advice
  #36 (permalink)
Old 12-21-2008, 02:02 PM
alberta 7.3 alberta 7.3 is offline
<- Insert Dana 60 here!
The 9008 has the same wattages as the 9007. You can get away with the adapters if you retain the standard bulbs. If anybody is in a pinch for headlight connectors for the 9008, here in Canada, Ford wanted 130.00 EACH FOR THE CONNECTOR!!!! Went to the Dodge dealer, asked for same connector for a 05-08 Ram, and paid 28.00 each. The downside of getting dealer parts is you'll have to splice in the connectors, since they aren't plug-and-play.
  #37 (permalink)
Old 12-21-2008, 02:16 PM
ford_trck ford_trck is offline
I blame the dog
Send a message via AIM to ford_trck
Whats the diff between the 9008 and 9007
  #38 (permalink)
Old 06-23-2009, 07:10 PM
czartony czartony is offline
Thanks! worked great on my 99 350.
