Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 08-17-2007, 01:06 PM
JBakerFX4 JBakerFX4 is offline
Question about Lift Blocks
The 3.5" blocks that came with my Skyjacker kit are "supposed" to go ontop of the factory block according to the directions. I saw a 6" or 8" kit riding around town and noticed he's got the factory block ontop, not bottom. I only have a 4" kit. But I'm making sure under compression I'm not straining the leafs. I don't even know if the factory bump stops will actually work. Should the factory block be ontop?
Old 08-17-2007, 01:34 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
Personally I would not stack blocks at all. It is strange for them to tell you that. Thats just my though
Old 08-17-2007, 01:54 PM
powerstruck powerstruck is offline
i would put them on top, i believe the factory blocks are angled for driveline alignment therefore they should stay tight to the axle. i to don't like the idea of stacking blocks.
Old 08-17-2007, 02:13 PM
RRonning84
Tournaments Won: 1
Posts: n/a
Ya dont stack the blocks but if you do I dont think it matters which is on top. My rear factory blocks are not tapered and if yours are not I would put them on top so as to retain your bump stops.
Old 08-17-2007, 03:19 PM
DieselFord05 DieselFord05 is offline
I have my factory blocks on top, and they are tapered. I have not had any issues with pinion angle. My kit is a 5" Pro-Comp Stage II. I did have to add traction bars b/c I would wheel hop when doing a burnout.
Old 08-18-2007, 09:00 AM
sloth sloth is offline
I wouldn't be crazy about stacking blocks. Regardless, I'd go with however the install directions indicate.
Old 08-18-2007, 04:05 PM
Install directions indicate having the lift block ONTOP of the factory block. I'm not a fan of lift blocks, but the Skyjacker 4" rear leafs don't have any overload protection. But I might look into new rear leafs of some sort for my 4" lift kit. Think of how many SD's are running around with Lift blocks and 99.99% I see are 6" or 8" kits. Those blocks are way bigger than my 4" kit blocks.
I just looked up the Leafs, about $600/pair. You do lose your overload protection leaf. (I wonder if I could take the leafs apart and put it in there from the stock leafs....hhmm). I also found a footnote that you can remove your factory block and buy 2" bigger springs. Like for me, instead of running the stock blocks with 4" SJ leafs, I could get 6" SJ leafs and run no factory block. For a bump stop I could fab up something on the top leaf plate that mimics the "ear" bump stop. Now I'm thinking!
Old 08-18-2007, 04:21 PM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
you could always get the new springs and add some air bags in the back so you wouldn't have to worry about your overload.....
