Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 08-09-2007, 05:35 PM
DFurman DFurman is offline
Question about Front End Geometrey
Alright so i sold my 35's today. O YEAHH so im gonna throw these pro comp front leaf springs i have in the garage on my bone stock 04 F-350 SRW. The procomp kit that these springs come in is 2" front lift 0 rear lift so basically its a leveling kit. In the procomp kit, there are 4 shocks, 4 ubolts, and the springs. No other brackets for the track bar, sway bar, or any of that stuff. When i put these on im not going to be seeing 1 or 2 more inches of my passanger tire vs my drivers side because of the lack of a track bar bracket am I?
I know sometimes lift companys dont always include the luxary parts in order to cut cost so i just want to make sure i wont hurt the geometrey tooo but adding these springs, new shocks, and 33's. Thanks fellows
Doug
Old 08-09-2007, 05:57 PM
gcop gcop is offline
PIPE HITTER
You should be even all the way accross.
Old 08-09-2007, 06:07 PM
Justinlw Justinlw is offline
Send a message via MSN to Justinlw
From what I've heard you can go a full 3.5" in the front without dropping the track bar, so 2" should be fine. I built 3" shackles and hangers, and the alignment shop had no problem getting it straight.
Old 08-11-2007, 05:39 PM
JBakerFX4 JBakerFX4 is offline
Not sure about the Leaf front ends, but on my '07 Coil spring front end I put 2.5" on and noticed a difference in how the axle set. It sits "correct" now that I have a 4" skyjacker kit which included a new track bar bracket. But technically, yes it will move it over. probly 3/8".
Old 08-11-2007, 05:42 PM
Logan Logan is offline
The Fat Mod
I did not have any change with my leveling kit.
