Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 08-07-2007, 07:53 AM
jwsland jwsland is offline
headlight bulbs
my stock headlights are nice but they arent very bright. i've never bought replacment bulbs before so i'm not sure what to buy. anyone else using aftermarket bulbs? something bright.
Old 08-07-2007, 08:46 AM
jfines@cox.net jfines@cox.net is offline
I don't know about bulb's, But if you need more light you can try "The Bright Box" from Geno's Garage(in sponser section)
It turns on the Brights and Normal lights at the same time. Without burning out your Mulit Function Switch.
Old 08-07-2007, 09:08 AM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
i run the xenon bulbs i have on my website.... they are much brighter than stockers and so far have had them on my truck for over a year with no problem... here is a link Stealth Automotive LITECH Xenon Charged Headlight/Fog LIght Combo (05-07 Super Duty)
Old 08-07-2007, 01:41 PM
willypscustoms willypscustoms is offline
i use the the Sylvania hids they are pricey but bright as hell i get flashed with my low beams on i also have different head lights.
Old 08-09-2007, 09:22 PM
mokancraig mokancraig is offline
I've been running Sylvania Silverstars, give a lot more light and are legal...
Old 08-09-2007, 09:29 PM
SgtStroked7.3 SgtStroked7.3 is offline
Send a message via Yahoo to SgtStroked7.3
you can go replacement bulbs but i doubt you will get the results you are looking for, i would replace the entire assembly like willypscustoms did, then they will be really bright. the stock headlights just cant do what a good set of clear HID's will.
Old 08-09-2007, 10:14 PM
alfajay alfajay is offline
I got the newest silverstars, like $50 a set., I noticed brighter and whiter light. DOT is strict + yearly inspection they check if they are legal. The newest silverstars I think aare a little brighter then the predecessor, not alot.
Old 08-09-2007, 10:15 PM
that is the truth.
Old 08-09-2007, 10:19 PM
gcop gcop is offline
PIPE HITTER
no doubt about it, I have sworn off halogen forever
Old 08-09-2007, 10:35 PM
Logan Logan is offline
The Fat Mod
I love my HIDs. I have them in with the factory housing. Works great and get people flashing me all the time because they are so bringt. They are set correctly too by the way.
