Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 08-05-2007, 05:55 PM
JBakerFX4 JBakerFX4 is offline
Dual steering stabilizers issues
Ok, I've put about 200 miles on my truck since I've had the 4" kit installed. and I had them put a dual steering stabilizer on, and I verified it's installed correctly. Per instructions of skyjacker. I noticed today that the driver side absorber is DENTED on the top! It looks like the Castle nut from the single Above steering stabilizer smashed into under suspension compression. Has anyone else had issues with this? Yes the bump stops are in place.... so the only thing I can come up for a idea fix is remove the driver side absorber and run only 1 on the passenger side and the single above, or remove the above one and run 2 below on the axle. Not sure what to do here.
Old 08-06-2007, 03:56 PM
Well I called Skyjacker, they said it's common on the 4" kit. You can run all 3 stabilizers on the 6"+ kits. But They said to remove the upper stabilizer and only run the dual kit on the axle. OK. What I planned on anyway...
