Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 07-30-2007, 08:58 AM
Lonno Lonno is offline
Lift help.
I have an 06 2WD on a 6" Fabtech lift. Now because of the weight of the front end its lower than the rear by a couple inches, and it bugs the F**k out of me. All the shops in town that I talk to say they wont stack lifts to help me get the front end up. Is anyone know if there is a simple way to do this, ie spacers or a leveling kit or something that won't max out my camber to where I can't align it.
Any advice would be great. thanks
Old 07-30-2007, 10:00 AM
Bump, bump, Help Help.
Old 07-30-2007, 10:39 AM
desertford desertford is offline
how is your front end set up?
Old 07-30-2007, 10:44 AM
cj41foley cj41foley is offline
Fat Bob's Garage: Ford 2" Front Spacer Lift Leveling Kit (w/ Extender Studs) F250/ F350 2WD 1999-2004 I have these on the front of my 06 2wd, there cheap, easy to install, you can still line it back up and I got about 1 3/4" of lift out of them.
Old 07-30-2007, 10:47 AM
how do u like that Fabtech lift, there the only one I've seen for a 2wd Super Duty, 35's about as big as you can go or what?
Old 07-30-2007, 12:02 PM
I have 6" springs, Bilstein alum shocks, dual steering dampner, dropped sway bar , bent angle radius arms(no rub) and new I-beams. The ride is sweet and soft compared to the 4x4's I've ridden in. I could probably go a little bigger tires if I can get the front end up 2".
Old 07-30-2007, 12:06 PM
That link says those spacers are only good up to 04's.
Old 07-30-2007, 12:16 PM
your right, but they told me they would work on a 05 06 or 07, mine is a 06 and they do work fine, I put them on myself, they go between the bottom of the coil spring and the front end
Old 07-30-2007, 01:08 PM
How much work was it, any special tools needed? thanks.
Old 07-30-2007, 01:17 PM
basic hand tools, floor jack, and I think a 32mm socket, very easy, I believe cjford has some pics on here somewhere of the job
