for the headlights open hood there will be 2 screws, remove them, then right below the headlight, there are 2 screws, remove them,, then you can remove the headlight. 2 remove the fog lights, remove the grill (this is very easy) then then you will be able to see the mounting screws for the fog lights, remove them. hope this helps. oh by the way to remove the grille, open the hood remove 4 screws from top of grille, then pull the grille out from the top, just enough to be able to get a long handle screw driver between the grille and radiator, so that you can release the clips at the bottom of the grille.
