I live in a dry dusty area where the wind blows a lot. I have found that my side windows that roll up and down have slight scratches in them. There is dirt getting in the rubber/felt seal along the bottom outside of the window. I hose it out occasionally and run my finger through it every once in awhile to get the dirt out. What are you guys doing to keep the scratches from showing up and keeping the felt clear of dirt? Any tricks or suggestions. Thanks.
Just clean them often! That is about all you can do.
I had my windows and felts replaced while under warranty, so I am extra careful now to constantly clean off the felts so I don't end up having to buy new windows.
My seals were also replaced with new glass as well....all scratched up again! only thing you can do is try to keep them clean + never roll down your windows. Scratches really stand out if your windows are tinted
Lol, good luck not getting scratches, I got some with about 5000 miles on my truck. Hard to avoid, and sucks especially with window tint like mentioned above.
I had the same problem with my 06. Like mentioned already, I took and rubbed my finger on the felt and also stuck a rag in between there when I was done washing mine all the time. I thought someone did a mod on this? Just cant remember what site I seen it on
my windows are also really scratched and some of you guys said that ford replaced it under warranty? what do i say when i go into them? any help be great thanks
If you (very carefully) pull off the outer window felt, you'll find there is an upward facing J shaped channel at the bottom of the felt against the window. This channel is PERFECT for catching mud and grit that gets by the uppper felt strip. Once it gets by the uppper strip, the crud just packs into that J shaped channel and grinds on your window like sandpaper.
It's damn tough to clean out this channel with the felt strip still on the door....
i had the same problem until i get new outside felt strips/ weather strips about 4 months ago they seem to be alot softer and fold down when you roll the window all the way down so far no more scratches
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
