| 6.0L Exterior Discussion Body and Accessories Talk |
Billet Grille Install
Okay, I can't seem to figure out how to put this thing together.
Here is what I have. ![]() I bought it used, so there is no directions. The billet part has two mounting tabs on the top, ![]() and four on the bottom. ![]() The grille shell has four bolts on the bottom, but nothing to mount to on the top? What do I do? I have no idea how to put this thing together. |
Are you sure those four are for the bottom? They may be the top.
I have almost the exact same setup except my tabs were straight and I installed the billet grille first and then put the outside ring on. You can see the results in my sig. BTW, you're a bama guy, if you're close enough I can just ride on over and help ya out. |
I figured it out a day or two ago, I just had to wedge it in, and it's as solid as a rock!
Thanks for the help though! Here's a pic:
looks good blake!
i wanted to get one for mine, but then started the 05 conversion |
Thanks man, I got it for $40, so I figured for $40, why not?
![]() And I can't afford the '05 conversion just yet, so I figure this will tie me over until I can! Still gotta get my FICM tuned and a coolant filter first, though. |
