Icon 4.5 hanger lift - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-13-2010, 07:37 PM Thread Starter
CCSBD's Avatar
What size rear block is best to level the truck out? Would it be a 5" block?
***SOLD***
'04 CrewCab ShortBed 6.0 4x4
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
Sinister Coolant Filter
Recon Smoked Cab Lights
SCT X3 Tuned by Innovative
4" MBRP SS Turbo Back Exhaust
ISSPRO EV pyro, trans, boost guages
CCSBD is offline
post #2 of 12 Old 10-13-2010, 08:43 PM
DCSpecial's Avatar
Yes, a 5" block will generally give you a level stance.
DCSpecial is offline
post #3 of 12 Old 10-16-2010, 06:56 AM Thread Starter
CCSBD's Avatar
Awesome, thanks DC. I think I am going to get a lift finally Then all I have left to buy are the rims.
***SOLD***
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
CCSBD is offline
post #4 of 12 Old 10-22-2010, 01:39 PM Thread Starter
CCSBD's Avatar
So would a 5" block be ok with doing 4wd launches or should I get springs in the rear? Has anyone had issues with that big of a block in the rear?
***SOLD***
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
CCSBD is offline
post #5 of 12 Old 11-02-2010, 06:04 PM Thread Starter
CCSBD's Avatar
So I finally ordered this kit. Is it relatively easy to install? Any special tools needed? and about how long would you say this will take for an average person?
***SOLD***
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
CCSBD is offline
post #6 of 12 Old 11-03-2010, 12:33 PM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
5" blocks will have more axle wrap than stock..you could use a Deaver rear 2.5" mini spring pack or Icon 5" springs..will have less than the taller block.
Kit will take 1-2 days depending on what tools you own and if you have a lift.
CT Performance, Inc. is offline
post #7 of 12 Old 11-13-2010, 04:36 PM Thread Starter
CCSBD's Avatar
Do the rear U-bolts have a specific torque they need to be at? Other than that the rear is done and the front is all apart ready to go together. Not bad for only working on it for 4 hours. Will have it finished tomorrow
***SOLD***
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
CCSBD is offline
post #8 of 12 Old 11-15-2010, 09:24 AM
Quoted: 4 Post(s)
150-180 ft pounds, use some blue loctight.
post #9 of 12 Old 11-20-2010, 06:11 AM Thread Starter
CCSBD's Avatar
Ok one last question...Is the bolts that hold the new trac bar supposed to be only 30ftlbs? That doesnt seem like that is very much...Is that correct?
***SOLD***
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
CCSBD is offline
post #10 of 12 Old 11-20-2010, 08:28 AM
Quoted: 4 Post(s)
Noooo, 400+ ft lbs. I use a 3/4" T slide handle and add 4' elect pipe to it and give it everything I got. Make sure track bar and all spring and shackle bolts are tq only with the truck on the ground...
