| 6.0L Exterior Discussion Body and Accessories Talk |
How do you remove head lights?
A friend of mine is trying to take his head lights off and is having trouble. He can't figure out how to get the bottom clip off. I haven't had a chance to look at it so I'm just going by his description. Any help is appreciated.
Four screws two on top under hood and two below parking lamps
Crowbar and large hammer
I'm not sure what year headlights you want to remove, but I just did it on my 05. It's super easy taking less than 15 minutes to remove. Here's the post with my write up when I replaced my lights last month:
How to change headlight assembly |
It's on an 03. It was dark when I looked at it, but all I could see was two clips on top and one on the bottom closest to the fender. I read tour write up.
I guess I should have asked if the ones from an 04 with a 6.0 fit on a 99-03 with the 7.3?
yes the lights from an 04 will fit the 7.3. for those headlights its easiest to take the parking lamp out first which is 2 screws on the bottom of each one. once those are out theres 2 little clips that you have to take out on top of the headlight. you will see them. and they will fight you. there a pain in the ***. after that there is one tab on the bottom on the inside the engine bay near the battery that is a spring clip basically. you would be best off pulling out bothe batteries to access each clip and then use a pair of pliers to release the clip.
