Cab Light Install? - Ford Powerstroke Diesel Forum
Old 09-28-2010, 03:57 PM
Cab Light Install?
How difficult is it to install the cab lights? I cringe at the idea of drilling holes in my roof.. Is the wiring already under the headliner for them? Is there a template avaliable somewhere for spacing and drilling holes?
Thanks
Old 09-28-2010, 05:48 PM
There is a thread somewhere on here where it was done on an Excursion. It didn't look hard at all. Search for it.
Old 09-28-2010, 05:54 PM
Its not hard. I covered the entire front 6-8 inches of my roof with painters tape and took the measurements from here and made my own template. It made it easy to measure, check, measure, check, check, measure, measure, measure, check, drill. Also, having the tape there makes it easy to prevent the drill bit from scratching the paint.
I started with a really small bit, then went up to the size needed for the bolt so it wouldn't slide around.
The wiring is not in the headliner, but the plug for the harness is just to the right of the passenger side footwell right behind that plastic peice. This and there are holes in the metal brace in the front of the roof for the plastic push pins that hold the harness up there so its simple. pull the a pillar plastics off, pull the headliner plugs, then slide it down out of the way.
buddy of mine had mine done in just over an hour with me being very anal about everything that involved drilling or cutting my truck.
Old 09-29-2010, 03:04 PM
Thanks guys...!
Old 09-30-2010, 11:58 AM
Painters Tape does wonders! its easy to do!
Old 09-30-2010, 12:16 PM
Here is a link to site that show how to do it on an F250. Shouldn't be that much different. It will give some idea anyway....
Motoman's Madness
Old 09-30-2010, 12:24 PM
Motoman's Madness
It was easy took about 1.5 hs
Old 09-30-2010, 01:06 PM
Doesnt look bad at all... I need to ge me one of those knock-out tools!
Old 10-22-2010, 01:12 PM
I want to add the cab lights but I have a sunroof. Does anyone know if they can be installed with a sunroof?
Old 10-22-2010, 04:41 PM
Pretty sure my neighbors dad has cab lights on his rig and I know he has a sun roof. Kinda sad I don't know for a fact, but he doesn't live in the neighborhood so I only see it every once in a while.
Oh, and welcome to the org
