Which Leveling Kit? - Ford Powerstroke Diesel Forum
Old 09-09-2010, 02:46 PM
Chapter Director
Send a message via AIM to Fantom
Which Leveling Kit?
While I'd really rather lower the truck, being a 4wd it's not going to happen. So, I'm thinking about just leveling it out since I'm already running 33's. So which leveling kit should I go with that won't cost me an arm and a leg, but is still a quality kit?
Old 09-09-2010, 02:57 PM
Feedback Score: 9 reviews
Go with a mini spring pack, or if you're on a budget like I was, just do an add-a-leaf kit. Rides like factory.
Old 09-09-2010, 03:59 PM
Yeah add a leafs are good
Old 09-09-2010, 04:31 PM
Feedback Score: 5 reviews
A mini spring pack willbe able to reuse the stock length shocks were a add-a-leaf may require longer shocks and should not ride as good as stock. Both should use a adj track bar to recenter the axle as it will shift aprox 3/4" We sell all but add-a-leafs. If I can help PM me.
Cary
Old 09-09-2010, 04:58 PM
As stated, bang for the buck a QUALITY mini pack will do the job. Its less expensive than a hanger/shackle kit and allows you to reuse your shocks. If you need to replace your shocks anyway, I would go with a hanger kit. Dont get a cheap mini pack, as all they are is bundled plate steel. Make sure the pack is actually spring steel. Cary at CT will sell you the right stuff. If you decide to go with the hangers and would like to consider ours, just shoot me a pm.
Old 09-10-2010, 06:11 PM
I went with Rancho 2.5" lift springs in the front and 3" Blocks in the rear. Running 295/65R20 nitto trail grapplers. Ive got less than 200 in the whole setup. Just had to look around the web to find a deal on the springs and got the blocks from a local offroad shop.
Old 09-11-2010, 07:40 AM
His is an 04 so its has leaves and not coil springs......
Thad
