Excursion Door Locks - Ford Powerstroke Diesel Forum
Old 09-02-2010, 07:11 AM
It looks like a few weeks ago, someone tried to break into our 2003 Excursion from the driver side, during the process the damage the door lock, I located then in ebay
2000-2006 NEW Ford Excursion Door Locks: eBay Motors (item 370016374428 end time Sep-09-10 03:52:54 PDT)
BUT If recall correctly someone had mentioned that a company sells these door locks that are bullet proof as it appears that our OEM are very easy to break in?
My question is, does anyone has any information on those door locks?
Old 09-02-2010, 08:08 AM
They broke into mine by sticking a screw driver into the key hole and turning, but I left it broke and took the inside door panel loose and disconnected the linkage at the lock and the only way you can get into it now is with the remote or key pad.
