Easiest way to remove door badges. - Ford Powerstroke Diesel Forum
Old 08-24-2010, 06:24 PM
Illiana Chapter Director
What is the easiest way to remove the door badges? Thinking about going with a different look and if I don't like it, I'll get custom ones made. Thanks guys.
Old 08-24-2010, 06:30 PM
Heat & fishing line as well as patience and a buffer
Old 08-24-2010, 07:13 PM
back to business
I found that heat makes the adhesive a bit messy.
I did one with heat and one without, the one without heat was quite a bit easier.
And yeah, the fishing line trick. Take a piece of fish line 10-20# sould be fine, double it over and twist it. You use that like a little "finger saw", get it started behind the badge and saw away.
After the badge is off there'll be a mess of left over adhesive, I tried a couple things to get it off. I had the best luck with a small plastic scraper and plenty of goof off. Just make sure you wash and wax after you're done, I'm sure that goof off strips the wax away like none other.
Old 08-25-2010, 06:04 AM
I did fishing line, with no heat. Just cut the adhesive with the line and started pushing the old adhesive around with my thumb until it balled up and started peeling it off, it was fairly easy and I did not have to use any chemicals at all.
Old 08-25-2010, 01:19 PM
I just got a grip on the edge of the badge. Both pulled off cleanly and you can't tell where they go since I cleaned up the truck.
Old 08-25-2010, 01:30 PM
Send a message via Skype™ to BigOlDog
I wouldn't suggest heat. But fishing line all the way. If you choose to do heat get the wife/girlfriends hair dryer and go at it that way. A heat guy and you can mess somethings up. I also want to say I seen something like a big eraser off of a pencil that you can put on your drill that will help with the glue. Just can't remember what its called.
Hope this helps
Old 08-25-2010, 01:31 PM
riddin' high
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
when i put my new ones on, i SOAKED the back of the old ones with wd 40 and let sit, took fishing line and worked it back and forth cutting through the adhesive, and then used googone to get the rest of the glue off. took like 20 minutes to get old off and new on
Old 08-27-2010, 10:37 AM
Are you talking about the fender badges like where is says F-250? or we talking about the Diesel badges? I want to do this too, but I have a question? Does it leave like any holes behind? or do they just come off and leave nothing but glue behind? I have an Excursion...
Old 08-27-2010, 10:47 AM
riddin' high
the ones on the doors dont have the alignment pins, the F250 fender badges or whatever do
Old 08-27-2010, 11:29 AM
peal them off.. dont need heat.. i did mine an just used a rag with soapy water as i pulled i wiped an they came rite off.. i filled all the holes an left them off all together
