4inch block? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-12-2010, 08:45 PM Thread Starter
Koda22's Avatar
Quoted: 5 Post(s)
4inch block?
ok guys sorry still a newbie, but i keep seeing and reading about a leveling kit with a 4inch block....now im thinkin that its for the back, because the leveling kit picks the front up to much....so can i do this to my truck? I got an 04 F250 4x4....and if i can, where can i get one of these blocks?
Thanks
Cody
Koda22 is offline
post #2 of 4 Old 08-15-2010, 07:35 AM
tcgordy's Avatar
id do a little less than that to make it sit exactly level. most everyone uses a f350 block when they install a front leveler. it will make the truck sit just about perfectly even on all four corners, b/c it is taller than our f250 block....
tcgordy is offline
post #3 of 4 Old 08-15-2010, 07:41 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
Mine is EXACTLY level, but still LOOKS like it is ever so slightly pre-runner. I would go with the 4" block if I had to do it again.
BTW, do NOT use blocks to lift the front; you MUST use lift springs and/or drop brackets.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 4 Old 08-15-2010, 08:04 AM
tcgordy's Avatar
of course my above answer go with you doing a 2.5 inch leveler up front, you didnt state which one you have.
tcgordy is offline
