how big before problems? - Ford Powerstroke Diesel Forum
Old 07-19-2010, 04:38 PM
was looking the other day and kinda want to raise my stock truck an inch or two (maybe 3).
ive known many ppl that just put a flat spacer between the axle and spring.
how far could you go without have to change the shocks?
also would pinion angle be changed enough to cause a new vibration or excess wear to the u joints?
would you create a "bump steer" condition with a 2 inch lift?
any other considerations?
thanks
Old 07-20-2010, 07:50 AM
Feedback Score: 5 reviews
If you get a quality level kit like a Icon or RCD with a adj track bar you won't have any problems. They will come with new front coils, castor shims and shocks. If its a F250 you will need a taller rear block and U bolts or the rear will be low. You may get vibration so a carrier shim kit is advised. If you need additional info or pricing please PM me.
Cary
