Moon Roof adjustments - Ford Powerstroke Diesel Forum
Old 07-18-2010, 06:02 AM
Question Moon Roof adjustments
Are there any adjustments that can be made for the factory power moon roof?
Mine is opening to far, past the darkener, and then will not close all the way.
I have solved that issue by not letting it open with the auto open feature, but would still like to know what would be causing this, as it has worked propoerly before.
Also when it closes, the rear right corner sits higher than the left rear??
I'd go take some photos to show what I mean, but unfortunately, it's raining again
Thanks for any help!
Old 07-24-2010, 04:58 AM
No one else has had an issue with this????
Old 08-27-2010, 10:19 AM
Need to bump this up, as I wanted to work on this todat, and on the left side, when sitting in the truck, there is a piece that is just sitting there, not hooked to anything.
Anyone know of where I could see a diagram of how the moon roof is attached?
Old 08-31-2010, 03:57 AM
Send a message via AIM to Powerlift34
I just got an 05 KR. With a moonroof. Too new to this, to help. But I hope you get it figured out!
