| 6.0L Exterior Discussion Body and Accessories Talk |
biggest tire selection
can I fit a 35x12.5x17 M/T under a '05 250 FX4 with no lift and no coil spacer ??
yes, my wife is the service manager at a OTR tire store and they do alot of pickup tires also and she has put on hundreds of stes on customers trucks. You can run them down the road but if you do any offroading they will probably rub under full turn and full flex
ltjds has 35x13.5x18's under his truck. Mickey Thompson ATZ's
OEM ride height
325/65/18 or 35x13.50x18 No rubbin here, even in light off road conditions... PS: Your main concern should be keeping with the OEM rim width do that and you should be FINE !!!
I'm running Pro Comp Extreme A/T 35/13.50/20 on stock wheels with no lift or leveling kit with no problems at all.
like it was stated above it will work with the oem wheel size and offset but with a wider wheel and bigger offset it will rub.
