which lift - Ford Powerstroke Diesel Forum
Old 05-15-2007, 09:00 AM
which lift
me and my buddy are throwing the idea around about lifting our trucks. Im not going to go over a 4" or less. I like the look of the superdutys at the 4" range with 35's. What lifts do you recomend? What are peoples opinions on the superlifts? By the way both of our trucks are 05's.
Old 05-15-2007, 09:03 AM
superlifts are a good product but if your only going with a 4" or less i would suggest Pro-Comp... its the best bang for your bucks setup....let me know if your interested and ill hook you up....
-Raul
Old 05-15-2007, 09:14 AM
-Raul
that is something to keep in mind. What does procomp do to compenate for caster, and trac bar lengths?
Old 05-15-2007, 11:00 AM
I have a 2004 F350 with a 4inch superlift and i love the ride and how easy it was to install myself
Old 05-15-2007, 11:27 AM
which shocks did you get? yours is leaf sprung in the front, mine is coil over, Im guessing mine may be a little bit more work.
Old 07-09-2007, 08:07 AM
has anyone had a donahue racing or skyjacer kit? pics?
Old 07-11-2007, 05:02 PM
a guy i know had a 2006 with a 8'' skyjacker ( i know you only want 4'') but he had the 37/13.50 with a 20'' weld rim and it rode like a cadillac. i am trying to decide on what lift i am going to get for my 03 and skyjacker is definately one to consider
Old 07-11-2007, 06:00 PM
my ride has a 4' pro comp w/double hoop shock up front w/315 pro comp a/t tires, but it was on the truck when i bought it.............
Old 07-13-2007, 06:13 PM
Barry
Keep in mind that a 4" lift may not clear 35" tires depending on the rims you may later choose. I have a 6" procomp and my 325/55/22's are rubbing when turned all the way. My old set of 35/18's barely cleared. unless you like stock width rims or 35" or smaller tires than a 4" will be good. Just something to consider.
Scott
Old 07-18-2007, 11:18 AM
Send a message via AIM to alk8778
Ive got an 8inch BDS full spring kit on my 03 250 with 37x13.50 r 17s and it rides like a truck. Very stiff and bouncy but its what i was lookin for. Great off-road, rough on-road.
