35's with level kit and factory 20's? - Ford Powerstroke Diesel Forum
Old 06-03-2010, 08:26 AM
I have an 07 crew cab F250 black, 275/65/20 factory tires that are worn and got the death wobble on the front end. I am wanting to know what i can do as far as bigger tire selection. What kind of leveling kit do ya'll recommend? And will a 35-12.50-20 tire work on the factory 20" wheel?
Old 06-03-2010, 09:18 AM
i recommend a Readylift 2.5" KIT. You can retain factory shocks and go with the 35" tire your looking to put on without rubbing. Its like $230 but its a nicce kit
Old 06-03-2010, 12:08 PM
I bought mine used with 35x12.50x20 on the factory rims. Not sure who made the leveling kit though.
Old 06-04-2010, 10:47 AM
I agree, Readylift 2.5" level kit is a real nice kit. And you can buy the blocks for the rear to make the rear higher and level from them also!
Old 06-04-2010, 02:13 PM
Feedback Score: 5 reviews
Buy a complete kit..you need coils, castor shims, adj track bar or drop bracket and shocks. Icon or RCD
Old 06-05-2010, 07:01 PM
295/65/20 nitto trail grappler MT. They are only a hair taller and wider than stock 275/65/20 tires.
Will the 295's fit without any lift??
Old 06-06-2010, 07:39 AM
Depending on what you are looking for and your budget I would go with either the BDS, RCD or Icon:
2005-2007 F250/F350 SRW 4wd - Truck Toyz Store
I would recommend an adjustable trac bar, however it's not "necessary" in order to complete the installation.
Old 06-06-2010, 09:37 AM
I have 2.5'' coils up front with adjustable castor shims and a ready lift 5'' block in the rear. Tires are Toyo 35''. However, I would suggest Readylift for the best bang for the buck.
Old 06-30-2010, 12:04 PM
I got that tire. I have been debating on taking the leveling kit off.
Old 06-30-2010, 07:02 PM
Well took it off and yes the 295/65/20s fit. Taking the 1" block out the back tomorrow and gonna straighten up the steering wheel.
