35" tire clearance question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-15-2010, 03:03 AM Thread Starter
timgreen_555's Avatar
Exclamation 35" tire clearance question
Hey all, I just put a rough country 2" leveling kit on my truck...I also bought Bushwacker Pocket Style fender flares.
I have factory 17"x7.5" wheels...
Will 35x12.50 tires or 315's rub in this application???
Also, how about if I put aftermarket wheels on later, will this be a clearance problem?
Please help with any input.
Thank you very much for your thoughts and time.
Tim
2005 Ford F-250 6.0l Powerstroke CC SB XLT FX4
-Edge Evolution Tuner, 4" SS Exhaust
-2" Leveling Kit, Dual Steering Stabilizers, Bushwacker Pocket Style Fender Flares, 35x12.5-17 Cooper STT
timgreen_555 is offline
post #2 of 6 Old 05-15-2010, 05:38 AM
I have a 4.5inch lift and no flares and my offset 35s rub a bit at full **** when bottoming out. They rub the little rubber fender well that goes under the truck. Not too worried about it.
madcat6183 is offline
post #3 of 6 Old 05-19-2010, 07:43 PM
theswoleguy's Avatar
Quoted: 9 Post(s)
Garage
anyone know where i can get some blocks? i assume i can run blocks on the front since the fronts are leafs? my 35x12.50R20s rub and rub hard to the point i cant turn really. Need these like hours ago.
2005 F250 Fx4, Crew Cab, King Ranch
8" Procomp Lift w/ ext. reservoir shocks, Trac Bars, 22x14 Fuel Mavericks, 38x15.50 Fuel MTs, O-ringed heads w/ valve job, studded, 5" exhaust, Fass Ti w/ RR, XDP Sump, Coolant Filter, Singer 270Amp Alt, BPD 58v FICM, S&B Intake, Powermax, S&B intake Elbow, Snow WMI, ID Tunes, TSD tunes, PHP Ficm Programmer (Atlas 80 majority of the time), Mishimotor Radiator & Intercooler, BPD Water Pump, Gates HD Serp Belt, Flex-a-lite E-Fan Conversion
theswoleguy is offline
post #4 of 6 Old 05-19-2010, 11:29 PM Thread Starter
I think most folks run Wheel Spacers, in the pre-2005 trucks, which have leaf springs up front...
post #5 of 6 Old 05-19-2010, 11:31 PM Thread Starter
Oh yeah, and I got my new Cooper Discoverer STT's put on yesterday...They don't even come close to rubbing. Loving them so far. I went with the 35x12.5-17
post #6 of 6 Old 05-20-2010, 03:49 AM
Quoted: 9 Post(s)
Garage
here is mine they rub hard like not even a full one rotation on the steering wheel...
