Adjusting headlight angle? - Ford Powerstroke Diesel Forum
Old 05-03-2007, 09:41 AM
Hello all, new member and first post......................
I have a 2004 F-250 crew cab SB 4X4. Here's my problem: The low beam headlight on the passenger side seems to have gotten out of whack and shines muches brighter than the low beam on the drivers side. I can't figure out how to adjust them so that they are at the same angle. My old 94 Silverado just had 2 little rods that you tweaked to adjust them. Hope this is an appropriate topic for this forum. Any help would be appreciated.
Old 05-03-2007, 08:33 PM
like to know how to readjust them also. After lifting my truck, headlights need to be readjusted.
Old 05-03-2007, 08:36 PM
PIPE HITTER
not 100% on the '04 but mine have 2 screws, one towards the front the adjusts horizontal position, and one behind the light housing closer to the outside of the truck for vertical position.
Old 05-04-2007, 06:24 AM
Rob Rob is offline
i had to adjust mine after my lift, there are 2 screws, one to adjust up and down angle and one to adjust the left to right angel, just turn the lights on so you can see them shine on a wall and turn the screws till you get your desired results. really easy.
Old 05-04-2007, 08:59 AM
Thanks!
Thanks guys! I'll give it a shot tonight and see if it helps.
Old 05-05-2007, 06:42 AM
thanks....will give it a shot one night.
Old 05-05-2007, 06:55 AM
SMOKE ROLLER
It's a breeze, you shouldn't have any trouble...
