Ford oval?? - Ford Powerstroke Diesel Forum
Old 04-26-2010, 06:04 PM
Ford oval??
I know i have seen on here how to remove and repaint the factory ford ovals?? But after to long looking here is my question. If anyone knows how to or where i can find the info on how to remove and repaint the Ford Oval please help.
Old 04-26-2010, 06:13 PM
Remove the 4 or 5 bolts on top of the grill, theres 4 or 5 clips at the bottom of the grill holding it in, pop them out, you should be holding your grill in your hands. lay it down, theres a nut type thing on the back of the emblem, and 2 clips holding it on. the hardest part for me was getting the film off of the emblem to prep it for paint.
Old 04-26-2010, 06:17 PM
How did you get the film off and what kind of paint did you use?? did you have to tape off the ford letters or did you use a brush to paint it? did you put a seal back on or just left like it was?
Old 04-26-2010, 09:14 PM
I took mine off, used a 60 grit to sand the majority of everything down. Then I took a finer sand paper and sanded it all out. Taped over the ford emblem with electric tape, cut around the letters with a razor then sprayed the emblem with a black rattle can from walmart. After it dried i used the spray polyurethane let it dry and did 2 more coats, it actually looks pretty good, and has held up since last october.
