Recon smoked mirror lens...HELP! - Ford Powerstroke Diesel Forum
Old 03-27-2010, 03:05 PM
Anyone replaced there stock lights with recon mirror lights?...they say there are 3 tabs behind the mirror..anyone got any pics of there install and do I need to pull apart the mirror shell or do I just pop out the old amber covers and pop in new ones?
Old 03-27-2010, 07:07 PM
Scroll down about 3/4 the way down the page and the instructions are there..........
Recon Accessories: Downloads
Old 03-27-2010, 07:10 PM
I put them on mine and love them.. My best advise??? Don't be scared.. lol. Seriously. Sack up and pry.. lol
Old 03-28-2010, 12:08 PM
I have those directions....what did u pry on the amber lense or what?...well it's rainin today so I am not even attempting them today
Old 03-28-2010, 12:11 PM
Rob Rob is offline
You have to manipulate the mirror and get to the tabs behind the glass. it is kinda tough at first. make sure you do not pinch any wires either. i did and had to redo all the work. also be careful not to break the butterfly tabs on the lights. they break easily.
Old 03-28-2010, 12:38 PM
So does the amber lense just pop out the side...or does the front of the mirror pop off?...I'm confused
Old 03-28-2010, 12:41 PM
Rob Rob is offline
You have to separate to two black plastic halves in order to get the lights out. Then replace the lights and put it back together.
Old 03-28-2010, 12:43 PM
Oh man that sounds great...so the shell comes off...well I guess I hope nothing breaks!
Old 03-28-2010, 12:50 PM
285,261,190
you will have to pull the back skin off the mirror to get to the light
To remove the back skin, adjust the mirror all the way in...towards the door window. Take a flashlight and look between the mirror glass and the inside of the back skin...you'll see the tabs I'm talking about. I would suggest using a headlamp on a band around your head...that way both hands are free. Insert a flathead screw driver and CAREFULLY pry up on the latch head...pry up too far and you'll break that tab right off. Once you get the first one to unlatch, move to the next one and repeat the process until they're all unlatched. Then simply pull the skin off from the outside of the mirror. you'll need to disconnect the small wiring harness to complete the removal.
To reinstall, simply line everything back up and snap the back into place.
Old 03-28-2010, 03:20 PM
Sweet...and yes "headlamps" are awesome!....best invention ever!
