| 6.0L Exterior Discussion Body and Accessories Talk |
Are 35 X 13 X 20 Toyo's Ok for stock rims?
just finished up my 2.5" leveling kit and I am ready to get some new tires.
I was looking at the toyo's (all terrain) and they have a 35 X 13 X 20. Would this be a good fit or is this tire too wide for the stock 20" rim. ANy other tire suggestions are welcomed! |
how wide is the stock 20" wheel?
8" wide i think
its fine, people run that setup all day including me
Ya its fine cause people will run 13-14" wide tires on a dually which are only 6.5 wide I believe
Really it just depends on the look you want. If you want the bubble look go with a wide tire like the 13 but if you want a more square look then go with a 12 or something a little less. Soory if it sounds weird but its the easiest way for me to explain it lol
Personally I dont like the bubble look but thats me |
The side bulge IS bad, it can heat up the sidewall and cause premature wear and possibly failure. It will cause premature wear on the center on the tread.
I know there are plenty of folks that run this setup, but it's not optimum. I wanted 35" tires, but did not want to spend the cash on wheels. I bought 285/75/18...35" tall and 11" wide. Cheaper, too. |
so what are some better options for me with a 20" rim?
How wide is the rim?
