max size tires - Ford Powerstroke Diesel Forum
Old 03-09-2010, 07:20 AM
max size tires
hey, whats the max size tire you can put on a nonlifted truck. my truck is a fx4 btw, specs in the sig. i would like to put 33x12.5x18. will these work? does anyone have this size on there truck, if so, you have any problems with them? thanks
Old 03-09-2010, 05:50 PM
yes those tires should definitly fit. i had a 1996 f150 and a 2000 f150 both stock suspension and i ran 33"x12.5" and never had any problems
Old 03-11-2010, 10:06 AM
and will tires not rub nowhere? i dont need to do any mod?
Old 03-11-2010, 03:17 PM
idk about the f-350 but when i had my f150 i had to trim a little corner off the bottom of the front plastic part of the bumper so that it wouldent rub in full lock. with the f30 i would assume that you would be fine and not have to trim
Old 03-11-2010, 04:12 PM
i run 285 75 16 on stock f250 2001 and dont get any rub what soever
